Prop shaft vibrations?
k17byo
Hi everyone ;)
I had a funny knocking under my 325i sport a few months ago under heavy acceleration, so I had a mate replace centre bearling and doughnut!
Since he replaced those it vibrates over 60! More of a shudder!
I asked him if he marked the prop up before splitting it but he said it only goes one way and that it's not multi splined?
Is this true?
Any advice?
Is this true?
Any advice?
- Homo Hair
Tech thread shirley?
fuzzy
iirc it has to be pre tensioned as well when fitting the centre bearing. im sure the two halfs of the prop can be mixed around if not marked.
kev76
needed marking . they are multi splined
Barx325i
props I've seen have two white blobs which line up from the factory, so if he hasn't marked it may be worth looking for them. As fuzzy says, the centre bearing needs a preload.. details will more than likely be in the zone wiki..
k17byo
I'm pretty sure the bearing I bought was already in the housing! I bought it all in one to save time and effort ;)
threelander
props need to be marked when taken off otherwise when you put them back they are out of balance.they only need to be one spline out and the create the noise you speak about mate
fuzzy
its a one piece item but it need to be preloaded on fitting.k17byo wrote:I'm pretty sure the bearing I bought was already in the housing! I bought it all in one to save time and effort ;)
k17byo
I knew it! Well I won't be using him again!
Do u know if the bearing is reuse able after bein used and under the assumption this muppet didn't preload it?
threelander
it.s a two piece item that needs splitting to replace the centre bearing so it needs marking before you split it but as you say needs pre loading when you refit it
fuzzy
the prop is a two piece item that needs splitting, the centre bearing is a one piece item than needs pre loading upon fitting iirc, its been a while since i did mine but i used to do them often... is the centre bearing the correct way around? iirc its slightly off centre on the carrier and will go either way as well. you should be able to reuse it.threelander wrote:it.s a two piece item that needs splitting to replace the centre bearing so it needs marking before you split it but as you say needs pre loading when you refit it
k17byo
That was another question I asked him but he assured me it only went one way!
Is there anyone in the brighton area that might be able to sort this for me? Someone that might have half a clue what their doin lol
fuzzy
my prop was custom made but i used the standard bearing and carrier, thats why im a little unsure .
threelander
do it yourself m8 not a hard job tye bearing goes on one way and one way only for anyone with an ounce of common sense. read the wiki files in here mate but its more like your man has not marked the prop when he split it and it is not balanced.easy sorted if you get someone what knows a e30 mate
threelander
hi fuzzy i,m baffled if you got a one piece prop how and why do you need a centre bearing and how do you replace it
fuzzy
no, the prop is a 2 piece and the centre bearing is 1 piece, with the bearing already mounted within the carrier when you buy it.
mrLEE30
The prop is multi splined but given the position of the two u joints there is really only a few obvious correct alignments, I.e so the u joints are in the same plane.
First pre load the centre bearing, (assuming you have not ripped the rubber mount), you will see the mounting holes are slotted, start with the bearing in its natural position, and hand tighten the two mounting bolts, then slide the bearing 5mm toward the gearbox and tighten in this position. If this does not cure vibration then your prop is misaligned or the donut is perished.
Also moved to tech section, Shirley.
k17byo
Thanks for all the advice!
I have got half a clue as I did restore the whole car myself!
This was the first person I'd ever let loose on my car and he makes a right mess of it :-/
Looks like I'll just have to find time to do it myself
