clunking noise when acelerating?
xSPARKYx
Hi all noticed today when i acelerate i get a cluking noise coming from the back could it be the prop bearing? any help would be good
mrLEE30
normally its the diff bushing, or the top mounts.
open the boot and bounce up and down, does it clunk? Yes then rear shoick top mounts to be inspected
does ti clunk when on motorway at about 50 and you put your foot down then let off?? yes then its diff bushing.
Check the diff mounting bolts and also the nuts that hold the propshaft to the diff.
threelander
check the donut between gear box and prop shaft
balilu91
i have a clunking noise due to the axle mounts.. gonna fix it soon..
xSPARKYx
thx for the replys will go check
Barx325i
could be as simple as the rear damper lower bolt which needs nipping back up..
