smoking oil
retroboyo
Post Sun Nov 27, 2011 11:32 am
Once I manage to get the m20b25 running which isnt easy, once the temp gauge gets to the end of the cold blue band the engine cuts out and I cant restart it. If I take the oil filler cap off I can see smoke coming out.
gnrsoul
Post Mon Nov 28, 2011 7:11 pm
is there a lot of smoke coming out ??
if the car has been running and is a running temp the smoke could just be the heat
i have seen this on a number of diffrent cars when hot ?
try testing the blue temp senser or maybe also check the thermostat
im sure someone else will have some input in this to hope you getto the bottom of it
retroboyo
Post Mon Nov 28, 2011 9:02 pm
Thanks gnrsoul, I appreciate the input. I think its heat related. I'm going to try and bleed the coolant more as I have changed the coolant.
Rtaylor2208
Post Tue Nov 29, 2011 12:06 pm
For Bleeding the best way I have found is:
1. Raise the front end of the car on ramps or axel stands
2. Set the Heater to full for the blower and to full hot
3. Get the car upto just below half way on the guage
4. Open the Bleed Valve on the top of the Thermostat (8mm spanner required)
5. Leave open until you can no longer see air bubles comming out. have a helper keep an eye on the temp guage just incase, dont let it go to red.
6. Top up the coolant.
7. Lower the car.
I have done this the last two times I changed the cooland and it has worked 1st time each time.
Post Tue Nov 29, 2011 1:17 pm
Check that the heater is blowing out warm air as you are warming up the engine. If not, be very careful, as this usually indicates an airlock, which can quickly lead to a cracked head.
For the running fault, measure the resistance from pin 45 of the engine ECU plug (above driver's right knee) to a good body earth, when the engine is cold, and again when the engine is at full temperature.
You'll find it easier to remove the plug if you unbolt the ECU. It can hang on the lead while you warm the car up.
retroboyo
Post Tue Nov 29, 2011 1:31 pm
Thanks guys, I will give your advice a go
HairyScreech
Post Tue Nov 29, 2011 2:45 pm
is it smoke or is it just condensation steaming off?
retroboyo
Post Tue Nov 29, 2011 3:22 pm
This might sound stupid but I'm not sure, it definately wasnt doing it before
