front bushes
Darb
Post Thu Nov 24, 2011 7:07 pm
Hello just been told the front rear bushes need replacing ( apparently there are front rear bushes . Not the rear ones on the back of the car ? ) does any one have a rough guide to price and how long does it take to replace them?
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Nov 24, 2011 7:23 pm
The Wiki has a list of all the rubber suspension components, with part numbers:
http://www.e30zone.net/e30zonewiki/inde ... Renovation
The prices on there are a bit out of date, but you can give the numbers to the parts dealers who trade on here and they will give you up to date price quotes.
rix313
Post Thu Nov 24, 2011 7:28 pm
Darb
Post Fri Nov 25, 2011 7:52 am
thanks but has anyone got a rough guide to how long it will take to replace front bushes. I have been quoted 3 hrs, does this sound excesive?
Post Fri Nov 25, 2011 7:58 am
3 hours sounds about right.
Its not just the labour - having access to the right tools is a big part of it - doing this job at home without a hydraulic press to put the new bushes in and press them onto the arms is hard bloody work - I spent most of a saturday morning trying to get one new lollipop bush onto the front arm - gave up, took it down to my local garage and they had both sides done in a couple of minutes.
Post Fri Nov 25, 2011 9:13 am
I recommend you replace them with genuine E30 M3 bushes from your dealer. Note that BMW sell them as a pair, so you only need to order one. If you order two, you will end up with enough for two cars.
The M3 bushes are a direct replacement, but are far more durable, and alter the suspension geometry slightly to improve 'turn in'.
Last time I bought some, they were just over £20, but probably a bit more now.
As with any front suspension work, the tracking will need checking afterwards.
Darb
Post Fri Nov 25, 2011 9:23 am
Thanks alot, just need peace of mind knowing that , i hate to think im being overcharged
