I redid my rear brakes last year to get through the MOT; new discs and pads, but the MOT tester showed that the right side was still weak, so I had the caliper rebuilt.
Tester saw an improvement, but still gave me an advisory, and I'm pretty sure he won't give me a pass this year.
If the brake is weak on one side only, am I right in the thinking it will be the pipe from the distribution block to the caliper? I'm not really looking forward to dropping the entire subframe to do all the plumbing...
Rear brake pipes - replace?
Grrrmachine
- E30 Zone Wiki / Team Member
- **BANNED**
No air in the pipe,of course?
Caliper still working properly?
Caliper sliding properly?
Both flexi's nice and supple?
It's the flexi that goes over the beam that is the 'playfull' one,it seems as if the mounting bracket position varies slightly between cars.Sometimes you can get a spanner on both sides of the connecter,sometimes you cannot.
Most usefull advice that I was offered some time back was to slice the flexi as close as possible to it's ferrule,then use a deep 14mm socket to hold the remains still and use a brake pipe spanner on the other side.When that fails to work
slice the hard line close to the threeway connector and break the spring clips out!
Then you can yank the lot out and replace all components.
Youth is wasted on the young.
Grrrmachine
I'd done a search and read all your excellent tips on this, daimlerman
I even have the same set of crow's feet spanners as you.
RealOEM shows that, from the T-piece, it goes hardline - flexi - hardline - flexi - caliper. Is that right? and in that case, it's the middle flexi you're talking about I presume.
Cor, even after all these years these cars make me feel like a novice sometimes
- **BANNED**
That's correct.Grrrmachine wrote:I'd done a search and read all your excellent tips on this, daimlermanI even have the same set of crow's feet spanners as you.
IMO,it's just not worth the hassle replacing one part here,for the cost of a set of flexi's and a bit of cunifer,spring clips and so on,do the lot in one hit!
Those crow's feet are exellent for attaching the new over beam flexi,hold with that and use a spanner on the other side.
Grrrmachine
can anyone confirm who the OEM manufacturer of these parts is? I'm getting prices of 22 quid from BMW for the flexis, but only 5quid for FEBI flexis from my local parts supplier...
- **BANNED**
I have fitted braided s/s flexi's!
OK,they are more expensive than plain rubber,but they should never,ever,need replacing.
BenHar
I don't think this is right. They give a harder pedal feel but they still have rubber inside the braid and it will perish just like any other.daimlerman wrote:I have fitted braided s/s flexi's!
Ben
Shouldn't be any rubber in these - the inner liner is PTFE.BenHar wrote:I don't think this is right. They give a harder pedal feel but they still have rubber inside the braid and it will perish just like any other.daimlerman wrote:I have fitted braided s/s flexi's!
Ben
These can last a long time, but when they do fail, they fail completely and without warning.
Grrrmachine
One last question; there's two flexis per side on the rear beam; 200mm and 224mm. For some inexplicable reason, my dealer can't get the shorter hose, so is there any harm in using the slightly longer flexi in its place?
I can't imagine 24mm is going to lead to a terrible kink
You buying them from BMW? If not get your parts place to look at the cars listed in the link below, they all use the same pipe
http://www.realoem.com/bmw/partxref.do? ... showeur=on
