Hi guys, here's a silly question! I've looked around the net and these boards, perhaps I'm using the wrong terminology - it does happen.
I bought a TRS tow strap and after studying lots a pictures of track car E30s I decided I'll cut a strip hole in the bumper and feed the strap through that. The trouble is, where can I get a bolt the right size to fix it to the towing point?
Didn't think it would be this hard but Halfords were completely confounded
Many thanks in anticipation of a very obvious answer that's elluding me!
Front tow bolt size, where to get one?
milescook
greggers
On ours (pre-facelift) the tow hook is integral to the body, it's welded on. If you have an Tec 1 kit fitted you essentially get a tow hook clamped over the body tow hook to extend its reach beyond the bumper.
Looking at the pictures of TRS straps on Demon Tweeks, I think you'll have to make your own mount/bracket to fit it, and you'll probably need to weld some extra strength into wherever you are going to fit it.
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
milescook
Cheers so far.mine is post face lift so all I need is the correct size bolt.just not sure where to find one?
threelander
hi miles what you are saying is that you need to know the size of the thread yeh
milescook
Yes please and where to get one.
If you're looking for the thread on the screw in front towing hook, the only place you'll find one is attached to a BMW towing eye. It's a very coarse non standard thread.
milescook
Ok thanks Brian. I guess it's off to the garage for a spot of welding then!
That will be why I can't find one... hope this helps someone else one day.
mrLEE30
I assume you have looked down next to your jack, where the tow eye is stored? Otherwise look at scrap cars or people breaking. Not hard to find.
milescook
I have the towing eye, but the eye bit oviously sticks out as it's meant to, which isn't ideal because I'll be using the strap. I guess get the garagae to cut it and use that as the bolt? As long as it's secure I don't care.
