Changing these steering bellows has opened up a can of worms...
I'm replacing the complete tie rod assemblies on both sides as per e30tech's article here:
http://www.e30tech.com/articles/steering/tierods/
drivers side is done, no problems at all. I cant undo the passenger side from the steering rack though. Its bent my molegrips and a pipe clamp! Have made absolutely sure that the folding tabs are back (i've hammered that locking washer to hell and back...)
How can i get it undone? Can't cut it i assume?
Tie rod removal from steering rack
318lemon
Jim320i
- E30 Zone News / COTM Team
Do you have access to a welder? You could try welding a long bar to it so you have the angle and leverage?
I'm going to be doing this on a 323i next week, which im not looking forward to
- **BANNED**
You need a bloody big spanner,I think it's a 27mm open ended one.
It will be FT tight,so make sure the car is well supported before lying under it using your feet to push/kick the spanner.It's a standard thread,not a reverse one.I think that they would have been assembled with thread lock...
Youth is wasted on the young.
318lemon
Really? Okay, I'm obviously not man enough
Will be back out there in the morning to try harder.
All that force can't hurt the rack can it?
- **BANNED**
You were man enough to do one side,other one is just the same!
318lemon
cheers DM - second time this week you've helped me out!
i used some mole grips tight onto it and against the wishbone to stop it moving and used a big prybar on the nut, soon shifted it
e30kid6
Jim320i
I did some today e30kid6... Same thing, one side had the locking thing, the other side didnt... The new set didnt have them either but we put them on without
Not sure how it would stop them anyway but seemed ok considering the last set had one missing and didnt look to have been changed for some time and nowt in the history of the car
