Wheel offsets with E36 Evo 5 stud set up ?
toadster987
Post Fri Nov 11, 2011 10:45 pm
I have just acquired complete e36 evo front suspension, brakes & hubs so aside from the mix of parts to get the geometry right I wondered if I do go ahead and fit them what sort of wheels I can run from the BMW wheel range ?
Also how has everyone over come the ABS differances too ?
Uploaded with ImageShack.us
Baurluvva
Post Fri Nov 11, 2011 10:52 pm
Im going to run bbs rc041's - 17" offset is 41mm and a high offset makes up for the difference of e30 and e36 hubs etc.
I am having a problem with rubbing though on the arb bushes at the mo, but was hoping the evo kingpins I have will solve it with some extra camber!
toadster987
Post Sun Nov 13, 2011 8:17 pm
I was thinking of similar wheels myself, has to be bbs ! , are those e36 sport ones ?
Baurluvva
Post Sun Nov 13, 2011 8:23 pm
Yes they are 328i sport 17's (front wheels all round) not the staggered set
toadster987
Post Mon Nov 28, 2011 2:38 pm
Iv seen a set of BBS RC040 fronts et41 and RC090 rears et20, does anyone know if this works out ok ?, Im planning on using compact ti rear arms
Post Mon Nov 28, 2011 3:17 pm
You need 041/042's
toadster987
Post Mon Nov 28, 2011 8:29 pm
looking though the wiki it does say that et20 is possible at the back with stretched tyres & rolled arches ? seems to be lots of pictures of e30s on the net with style 5's which are quite often low offsets...
Post Mon Nov 28, 2011 10:01 pm
They will be running e30 M3 5 stud.. E36 stuff is ~20mm wider per side
Baurluvva
Post Mon Nov 28, 2011 10:19 pm
Is there enough material on the backs of the wheels to remove 20mm?
toadster987
Post Mon Nov 28, 2011 10:24 pm
Good point thats the e36 down side then being 20mm wider
Not sure if wheels could be modified but there bbs style 5's
Post Mon Nov 28, 2011 10:40 pm
Baurluvva wrote:Is there enough material on the backs of the wheels to remove 20mm?
No!!
Baurluvva
Post Mon Nov 28, 2011 11:40 pm
Could you flare the arches enough to accommodate them?
