As above, i changed my TPS and now I have a rough idle after a few seconds.
Can anyone shed some light on this?
I have checked for air leaks but i cannot find anything.
E30_Crazy
Try cleaning your ICV. Also try putting a multimeter to the 3 pins on the ICV. IIRC it should be ~20 ohms on either outer pin and the middle one, and ~40 ohms for the two outer pins
bm_guy
I have cleaned the ICV, check the ICV all seems fine.
Also had the injectors ultrasonically cleaned.
The problem goes away as the car warms up, when up to temperture it runs really sweet especially with the new injectors.
Leads dont have any cracks
What else should i be checking?
mrLEE30
Blue temp sensor next to the thermostat. Use the multimeter set to measure ohms. Find the blue temp sensor located toward front of engine near the inlet manifold and where the coolant hose leaves the engine remove the Plug and measure the resistance across the terminals. Should be around 3k when cold and about 250 when hot.
bm_guy
Sorry meant to add I have already replaced the temp sensor
E30_Crazy
It could be bad wiring from the sensor to the ECU. I can't remember which pins they are, but you can check for the same resistance of the sensor at the ECU plug.
EDIT:
Pins 24 and 45 of the ECU plug should read the same as the sensor.
EDIT:
