Washer fluid warning light
shornbuc
Hi , my washer fluid level warning light on my check control on my e30 1990 325i touring keeps coiming on once I am gone round the first corner or hill. Does anyone have any ideas how to resolve this ?.
kam-325i
WWWOOOOHHHHHHHH
Big Avatar
Big Avatar
haffeel
Well, I drove around town with the washer fluid lamp on for one month and finally I got fed up
I filled in water in the plastic can for wind screen washer tank.
Since then no lamp.
Hhhmmm now it is boaring No lamp on the Hood to indicate some thing important need my attention
Since then no lamp.
There's another washer bottle in the back, don't forget.
ian332isport
It's also quite common for the float sensor to rotate in the bottle and give false readings.
Make sure the sensor has not moved in it's hole.
Ian.
Ian.
Rich25i
Hi i had this problem when i put my washer system back to gether after a good clean out. The sensor was not put back in the way it come out and the light stayed on for 2 weeks while i moved the sensor round bit by bit.
Hope this helps
Hope this helps
doug325i
Does the one in the boot actually have a sensor?
I had this problem a few weeks ago, I cleaned all the sensors and cleaned all the contacts, works fine now. I think its because the sensors have a tendancy to get when when being filled - splashs
Just need to check every now and then.
Doug
Doug
Resevoir in boot has a sensor.doug325i wrote:Does the one in the boot actually have a sensor?
Doug
Getting the sensors wet when filling will not cause problems - it's all low impedance, low voltage circuits.
doug325i
Brainmoooore:
No but it still causes corrosion to the contacts...Getting the sensors wet when filling will not cause problems - it's all low impedance, low voltage circuits.
Not if you assemble them with silicon grease like I advise!doug325i wrote:Brainmoooore:No but it still causes corrosion to the contacts...Getting the sensors wet when filling will not cause problems - it's all low impedance, low voltage circuits.
Lordschleife
Go round the corners slower?shornbuc wrote:Hi , my washer fluid level warning light on my check control on my e30 1990 325i touring keeps coiming on once I am gone round the first corner or hill. Does anyone have any ideas how to resolve this ?.
I always found it acted as a g-force indicator on my 325i
The only solution was to keep it topped right up
Theres always something on a car if you go round a corner fast enough, previous car used to change radio station
Cheers,
Robin
Robin
doug325i
Brian :
too true.
Will remember that next time - keep up the good work, it's good to have a Guru around. I wish i new half the stuff you know.
Bon Nuit
Doug
Bon Nuit
Doug
chief
the car in this larrrrrge avatar , is it the one on e-bay ???
shornbuc
Just wanted to say thanks to all those that helped - rotated the sensor just once and I must have found the correct position. Drove 100 miles today and it never came on.
