Need mapping help.
badassyas
Post Sun Oct 23, 2011 5:46 pm
Basically Ant is unavailable and my car needs to be mapped.
The story is as follows, the engine had been rebuilt and ants maf kit and ecu had been supplied. His EPROM had been giving issues so the car was taken to him and an ostrich emulator was supplied and the car ran fine. I took it to Europe the next day for 10 days. It had been spot on till the morning in a nurburg hotel car park the emulator lost it's files. So the car was recovered back and a working eprom was supplied whilst the ostrich was sent for investigation... I have been using this EPROM with no issues but feel as if it needs a tweak here and there. I am happy to buy an ostrich and supply it to whoever can help me.
The issue is ants maf data being workable by someone else if he never gets round to it.
I am also happy for someone to supply the base map for a similar setup and then get it tweaked by a mapper...
Engine specs:
525e block, crank, rods.
KS high comp pistons.
Lightened standard flywheel.
Crank rods pistons balanced lightened and shotpeened.
324td oil pump.
Decked block.
325i cylinder head
272 catcam.
Gasket ported exhaust ports.
Gasket ported inlet port and manifold ports.
New standard valve springs.
Bbtb.
R G M 20 manifold and scorpion centre and rear.
Lambda probe fitted.
Volvo maf kit.
miniblob
Post Mon Oct 24, 2011 8:19 pm
I was also 'getting round to' some mapping from Ant on my 2.7, which unfortunately won't be done by him now.
I've been chatting to a guy at Circuit Motors (near castle comb) and have only heard good things about him, but he seems unsure about how to work the MAF conversion.
Might be worth giving him a bell though!!
(Can't find his number now so you'll have to google it!!!!!!!!!)
Was also chatting to Gunni (well, pm!) who seems highly regarded, but is a very busy man!!!!
Any other suggestions for us?????
327 Touring with bass!!!
Gunni
Post Tue Oct 25, 2011 9:56 pm
MY schedule should open up a bit in a few weeks time. I can handle your tuning requirements.
Gunni
@ 2012 VEMS group buy !!
badassyas
Post Tue Oct 25, 2011 10:00 pm
Wicked!!!!!! Thanks ever so much. Please keep me posted. :D
blingsta
Boost Junkie
Post Tue Oct 25, 2011 10:13 pm
whats happened to Ant ? too busy?
badassyas
Post Tue Oct 25, 2011 10:30 pm
Well i ain't certain but I seen this and thought bugger...
e301988325i
Post Wed Oct 26, 2011 11:09 am
This thread may assist Paul @ circuit motors with the MAF side of things:
http://www.e30clubsa.co.za/forum/index. ... -maf-swap/
I said:
e30topless said:
lock the wife in there
Quaser
Post Wed Oct 26, 2011 11:51 am
Paul has done maf conversions, as he did mine!!
