Valve clearances
chopper
Hi can anyone tell me the valve clearances on a m20 head? It's an 2.5 auto, the mechanic has rebuilt the head and said he need to know what the clearances are before it gos back together, thanks in advance
Jim320i
- E30 Zone News / COTM Team
0.25mm with a cold engine.
Andyboy
- Alpina Colada
If it's a plastic bumper 325i, the exhausts like to be set a bit wider. Many (myself included) have found that they idle better with the exhausts set to 12 thou as opposed to the 10 thou that BMW quote for inlets and exhausts. It may well be okay set at 10" all round, but bear it in mind. Always set the tappets with the head on the engine and bolted down. If you do them with the head on the bench, they will probably close up with the head bolted on.
chopper
It's a chrome bumpered cabby, yea he's got the head bolted on just needs to set the valve before he can crack on
