Help needed guys. Just checking the wiring at pin 20 on the c101 plug and it is brown on the engine loom. Pin 20 on the body loom at c101 is red/yellow.
What shall I do? Engine is m20 2.5 facelift.
I've read Brian wiring help but can't find anything with brown wire on engine loom? Thanks.
Wiring help pin 20
tom325sport
- **BANNED**
Check whether there is any wire connected to pin 20 on the car loom side of the connector. If there is, it will either be red/yellow or brown.
If it is brown, cut it away from the pin, and make sure the free end can't come into contact with anything.
If it is red/yellow, then leave it alone - it's the power feed for the ABS system. You will then have to check pin 20 of the engine loom side of the connector, to see if it has a red/yellow as well. If it has, all well and good, but if there is no red/yellow fitted, you will have to add one, between the pin and the terminal of the DME relay that has a red/blue on it.
(copied from the engine wiring sticky in 'engine swaps'...original post on page two by Brian)
Youth is wasted on the young.
tom325sport
Thanks. I have checked this but I have a BROWN wire in the engine loom at pin 20, not red/yellow.
There is red/yellow on the body loom though. Can I plug this in or not?
- **BANNED**
All the infor for both side of C101 was there!daimlerman wrote:--------------------------------------------------------------------------------
tom325sport
OK had another read but there explains nothing if I have a 'brown' wire at the c101 plug engine loom side. It says you either have 'red/yellow wire' or 'none'.
Quote from that post...
Am I reading it wrong? If the wire (engine loom side) is anything but red/yellow then to add one? Thank you.
- **BANNED**
As I read your posts,you have a red/yellow on the car side of C101 and a brown on the engine side?
As I understand Mr Moore's wiring warning in the Engine swaps section,that brown wire may well be an earth from the temp gauge sender,which is not used because the temp gauge sender is earth via the engine.
Now I also understand that the red/yellow on the car side goes to the ABS,the feed,I think...so unless you modify the engine side pin 20,you will have no feed to the ABS,so the ABS light will not go out,MoT fail....so you need to run a suitable wire from the DME relay terminal with a red/blue attached to pin 20,and dis-connect the brown wire.
tom325sport
Yes that is correct.daimlerman wrote:As I read your posts,you have a red/yellow on the car side of C101 and a brown on the engine side?
Thank you for explaining it to me. Much appreciated!!
What year is your engine loom from?
tom325sport
When I bought the engine (facelift) the loom was all boxed up and off the engine. I think it all came from the same engine as I saw it advertised on here. I'm sure the car was a 1988.
Here is a picture of the engine loom c101 plug. Pin 20 shown with brown wire...
Very strange - never seen one before.
The other end of it should be to one of the pins on the injector loom plug. The earth wire usually exists in the injector loom, but just ends at the socket to the engine loom.
As daimlerman has said, you will have to re route this wire to the DME relay pin with the red/purple. This will feed 12 volts + to the red/yellow on pin 20 of the body loom, when the ignition is switched on.
tom325sport
Super stuff!! Thank you for your help.
