Stalling at idle
cee
Occasionally (maybe once or twice a week) the engine stalls when I come to a stop (with the clutch in). What is this likely to be? ICV?
Not sure if it's relevant; but the stalling is so gentle I often don't notice it.
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
does it only happen when the engine is cold ?
you could have a seized icv or a split intake hose
what's the rpm on tick over,it might just need turning up a tad
+ a yard full of scrap turds
cee
My intake hose was ruined when I went for a Dyno session in March and Rich @ Fritz replaced it with a repaired one and tuned it so I'm thinking that should be okay. Idle is just below 1000 (So maybe aprox 800)magpie wrote:does it only happen when the engine is cold ?
you could have a seized icv or a split intake hose![]()
Only happens when engine is warm
fritz has fooked your car then
cee
Hahaha why's that?
coz it stalls
cee
So you don't think it could be an issue with the ICV?
turk
Its worth cleaning the icv, but if it been tuned id say the idles either been set too low or the throttle position sensor is duff.
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
cee
Well I may be be up that way on Wednesday morning so I'll pop into Fritz if I have time and get it checked.
cee
Just for reference, what should it idle at?
turk
around 800-850 once hot.
Sump Baffles
TrackDays
Sump Baffles
TrackDays
7500 is the idle speed without the choke on
cee
Okay I have a development. Went out for a drive this evening and noticed what the problem is. Idle is fine, however when pulling up to a junction, dipping the clutch as I roll in, the revs drop sharply to around 500, and sometimes drop just below, which seems to cause the stalling.
Grrrmachine
- E30 Zone Wiki / Team Member
That would suggest a gummed up or knackered Throttle Position Switch as the first culprit.
turk
YUP, agree /\Grrrmachine wrote:That would suggest a gummed up or knackered Throttle Position Switch as the first culprit.
Sump Baffles
TrackDays
Sump Baffles
TrackDays
THERE IS NO ADJUSTMENT FOR IDLE SPEED ON AN E30. DO NOT ADJUST THE THROTTLE STOP, EVER.
The operation of the throttle position switch is the first thing to check, along with the repaired???????????????? air pipe.
e301988325i
Also agree with gungy TPS.
I'd also clean inside your throttle body and the edge of the butterfly's for good measure.
I said:
e30topless said:
lock the wife in there
cee
Okay, thanks guys. project for next weekend then
