temp on 316
gaszman
- E30 Zone Meets/Events Team
the gauge stayed just above half new viscous fan is this correct
- **BANNED**
The temperature gauge shows a large range up to the first white mark and a short range between the three white marks,then a large range at the top of the gauge,there is a term for this but I cannot spell it...
Say from 0 to 80,then 80 to 90,and 90 to 150,so the temp anywhere between the centre three white marks is acceptable,what is not acceptable is sudden un-explainable changes.
I would suggest that your radiator is losing efficency,not blocked,but the tubes are starting to get clogged up.Removing and 'back flushing' will help a bit,but Mr Moore does suggest that an E30 radiator should be an 100,000 mile service item.
Youth is wasted on the young.
Marginally higher than most, but it depends on the rating of the thermostat you have fitted.
gaszman
i havnt fittef a stat but will
