Air Plenum
CHR1S1990
Post Fri Oct 14, 2011 5:42 pm
Coming to the end of an M20 ITB project and I need to do something about the plenum.
Original plans was to make one out of fibreglass and ive got everything ready, but ive just stumbled across a carbon fibre tube. It holds around 6L of water, but it doesnt look massive at all (I had planned to make one 3L in volume). My question is, I know a lot of stock manifolds are tubular (especially turbod cars) with a throttle on one end, but will a tubular plenum work with ITBs and an 80/70mm flange in the centre of the tube?
Ill get a picture up in a moment if nobody has a clue what im trying to describle. My main worries are:
1. the 6L volume is going to be way too large - do i need to worry about gas velocity/throttle response with such a large plenum when i will have 6 ITBs which are closer to the head?
2: will the tube provide a nice equal gas flow to all 6 runners fed from the centre?
educated thoughts much appreciated
CHR1S1990
Post Fri Oct 14, 2011 6:04 pm
the end is taped up just so I could fill it with water. Plan is to form the ends with fibreglass once the flange and trumpets have been bonded on. Or simply make the whole thing out of fibreglass and save the trouble.
CHR1S1990
Post Tue Oct 18, 2011 10:39 pm
wow, this must be a boring topic. perhaps this will liven things up a little:
[youtube][/youtube]
obviously running very lean without the AFM/TPS load signals hence the popping, but that will be sorted tomorrow. decided to make my own plenum rather than use that carbon tube due to space constraints
