Guys
The tubing to the rear washers on our Touring is leaking. Difficult to be precise where, but it seems to be near the hinge under the headlining. Has anyone changed this tube before? Any tips would be welcome-for instance, how do I drop the rear of the headlining to have a look?
Cheers.
Touring-changing rear washer tubing?
rover-2000
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
toby
reposted from here;
http://www.e30zone.net/modules.php?name ... ing+washer
Brianmoooore wrote:Typical BMW attention to detail! Any one that has a kinked pipe, has a pipe that's been refitted incorrectly by somebody.toby wrote:Something else I noticed was that there's a special little hole in the pillar to feed the washer tube through and a cable tie next to the hinge to stop the tube kinking and splitting.
Unfortunately, the constant bending of the pipe will eventually crack it and you get the en suite shower effect.
Switch the pipe around end to end so that the break is part way up the rear pillar, cut out the damage, and use a joiner to repair the pipe.
rover-2000
Thanks-that's useful. What I need now though are specifics as to the best way to remove the hose-I can't even see how to remove the rear pillar trims/rear headliner and I don't want to break anything.....
Kind regards
John
1989 320i Touring
John
1989 320i Touring
You don't need to remove any trim other than the plastic that covers the hinge ( just unclips ) - you should then see the hose.
Mine was split right by the hinge so I just trimmed the split part off, pulled a bit more through and re-joined it - job jobbed.
If you need to replace the pipe just tape a piece of string to it, pull it through from the washer bottle end and then just use the string taped to the new pipe to pull the new section through.
