Alternator belt
m8782538
Post Wed Oct 12, 2011 12:51 pm
Just realised that my alternator belt is rather slack and the alternator adjusted as far as it can go so i need to change it.
Apart from operating the fan, what else does is connect too? anything i need to be wary of before i replace it? (seems to be connected to another pulley at the bottom of the engine).
Duke137
Post Wed Oct 12, 2011 1:06 pm
Is this on your M10?
Post Wed Oct 12, 2011 1:24 pm
The pulley "at the bottom of the engine" is the one that drives the belt!
To replace the alternator/pump belt you will first have to remove the air con belt, and then the power steering belt, if you have either of these fitted, as they also drive off of additional grooves in the bottom pulley, and the alternator belt is the inside one.
m8782538
Post Wed Oct 12, 2011 2:48 pm
M10 316i, no air con, no PAS, pov spec.
So it should be just the drive pulley, fan and alternator?
