I'm selling a 3:91 slipper and have been asked the question, can you connect 320 drive shafts to a 3:91 slipper from a 325? I would assume the length is not going to vary but as the power out put is slightly different they might be different.
Any help on this appreciated.
drive shaft specification help
Tedswagon
- E30 Zone Meets/Events Team
Should be ok, as the output shafts on a smallcase diff are longer, and vice versa on the largecase.
All I did on mine when i swapped it was unbolt one, and bolt the other up.
yes it will be fine ,
Tedswagon
Cheers for replies.
