Rear Beam Help
hazd31
Post Sun Oct 09, 2011 1:20 pm
We trying to remove the rear beam
Any ideas of how to get it off, everythings undone but it wont come off the 2 mounts.
Any ideas?
hazd31
Post Sun Oct 09, 2011 1:56 pm
johnl320
Post Sun Oct 09, 2011 2:03 pm
support the trailing arms to stop the beam from trying to twist, remove the rear seat bottom to allow you to knock the bolts up from the centre of the beam bushes. Once they are out put a drift or extension bar up the centre of the bush and tap the bar from side to side to loosen it from the chassis, It may snap and leave a small ring of metal in the chassis, if it does then use a drill or dremel to remove the remaining material
hazd31
Post Sun Oct 09, 2011 2:42 pm
really struggling, pushed the bolts through no problem, but we cant get it to move. broken a sledge hammer and a rubber mallet full of ball bearing.
cant get it to move :(
Post Sun Oct 09, 2011 3:02 pm
I always run a hole saw up through the rubber, which allows the beam to just drop away so that you can deal with the remains of the centres with nothing in the way.
Any method of destroying the rubber?
johnl320
Post Sun Oct 09, 2011 3:53 pm
My IS rear beam fell off, leaving the centres in place, thats how knackered the bushes were, mot man didnt even spot them 8O
hazd31
Post Sun Oct 09, 2011 5:01 pm
hole saw and some abuse did the trick
Just set alight to the bushes to get the metal bit out, then in with the new subframe!
Barx325i
Post Sun Oct 09, 2011 5:26 pm
Brianmoooore wrote:I always run a hole saw up through the rubber, which allows the beam to just drop away so that you can deal with the remains of the centres with nothing in the way.
I like that one..
Then assemble a hack saw inside the remains of the bush in the beam - saw through the metal collar allowing it to deform - it will then tap out without too much of a problem.
johnl320
Post Sun Oct 09, 2011 6:10 pm
good time to renew some brake pipes
Post Sun Oct 09, 2011 6:36 pm
hazd31 wrote:hole saw and some abuse did the trick
has the beam lost the top diff mounting holes ? I would locate another if it has,
hazd31
Post Sun Oct 09, 2011 9:36 pm
This was the reason for the swap, good excuse to put the correct ratio diff on too!
Snapped 2 mounts, one bolt and was hanging by the last bolt all twisted!
johnl320
Post Sun Oct 09, 2011 10:02 pm
why bother burning the remains out of the knackered beam then?
