Hi i wanted know.... Would a 3.64 diff (325i) non lsd fit into a 320i? Straight fit or any mods?
Thank u for the help....
Ajay
Diff help please...
Ajsingh
E30 Crazy!
Andy325i
Sure would, but would just make it slower to accelerate I guess. Better top end though
- **BANNED**
Assuming that the 320i has a small case 4:1...65mph at 3000rpm
3:64 will give 73mph at 3000rpm.
If the 3:64 is a medium case diff(small one's have 6 bolts to hold the rear plate on,medium one's have 8)and has come from an E30,it will bolt straight in,BUT,(there's always a but!)the prop shaft will need shortening by about 13mm,this is easy,just slacken the collar nut close to the centre bearing and push the rear half of the shaft forward.Or use a big Birmingham spanner on the rear flange.....
When removing the diff,remember to unplug the speedo feed....
And if doing the job laid on your back,go back every 6 months and check the diff mounting bolts for tightness...
Youth is wasted on the young.
