just changed over intrumet panel
JC1989
hi , was having trouble with my clocks, and rev cunter and mpg meter wasnt working properly, well when i swtched ignition on it the revs flicked from 0-1000 then when reving it when up and worked sometimes but then would stop working all together.
for the sake of 20 quid i went down the scrapyard and got some other clocks, which i have now plugged in and the rev counter sits at 1000 and doesnt move.
i have checked both circuit boards in these clocks and they seem fine ( no battery leakage)
i have also checked fuse number 21, which original was 20amp when it should have been 7.5 but upon changing did not make any difference.
what else could these be, could it be wireing ? what else should i check, many thanks
Jack
Jack
Billwill
Did you replace the whole cluster?
Apparently there is a plastic "coding" plug in the rear that you may need to swap over...this differentiates between 6 cyl and 4 cyl models.
rover-2000
JC1989 wrote:rev cunter
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
JC1989
ahh i did not know this? and it was a 4cylinder i took it out of. what is this coding plug thing then ? is it just the blue plug?Billwill wrote:Did you replace the whole cluster?
cheers
jack.
mb15
It's on the front bottom right of the cluster unit as you look at it.
A little white/cream plastic chip/plug that you squeeze the sides of and slot it out.
JC1989
oh rite, ye changed them over, not alot was hapening do i have to reprogram the unit? or leave it in for a while etc, what code shuld be on the one i need for a 6cylc and for a 4 cylc
cheers
cheers
Rev. counter will still work with the wrong chip - just reads wrong. Nothing to reprogram either.
What type of batteries do your two SI boards have? AA sized NiCd batteries or much shorter lithium cells?
Make sure the lockring on the C101 main engine loom plug, next to the fusebox, is screwed right down. The rev. counter is sensitive to a poor connection here. (Black wire.)
JC1989
oh k , both boards have lithium batteries in , they are both half size aa batteries in them , on inspection both printed circuit boards are both clean with no signs of leakage.
i havent checked that c101 loom plug , will check tomorow,
seeing as both rev counters do different thing when plugged in could it come down to me having to sets of duff dials? altho is it only the printed circuit board that can be the downfull of these dials?
many thanks
many thanks
JC1989
bu the way , if anyone could post up a picture of what a c101 plug looks like would be apreciated have searched on here and also looked on ebay to see if i could see what it looks like cheers.
JC1989
just checked the plug next to the fuse box took apart checked connections and put back to gether again ( i guess the c101 is the one that has 2 parts that screw together almost)
i also replaced every fuse with new ones today
no difference what so all, checked both circuit boards again on dash dials and they both look fine?
god knows whats the matter,
does anyone who lives local to me have a working dials with working rev counter on icould try to see if i have 2 sets of dodgy clocks
will be beer money in it for you
cheers
Jack
cheers
Jack
These batteries don't cause problems like the NiCd ones do. Even if they fail, the only effect is loss of the SI information if the main car battery is disconnected.JC1989 wrote:oh k , both boards have lithium batteries in , they are both half size aa batteries in them
They do, however, have their own collection of (odd) problems, the most common of which is reading about 1000 RPM on the tacho when the engine is off.
I think it's very likely you have replaced one duff board with another duff board.
JC1989
rite u are spot on correct! one of the boards does display just 1000 rpm with the engine off, so i guess this is a duff
and the other flickers around like a crazy maniac when revving,
is this a case of getting new batteries? are these soldered in, look like there just pressed in, or is it a case of buying a new board (dials)
thanks for all your help
jonny323i
ive got 2 sets of clocks both should be ok especially one as i took it out of a working car if you want to buy another set
Touring for life
Batteries are all of the type with tags spot welded to the ends and are soldered in.JC1989 wrote:rite u are spot on correct! one of the boards does display just 1000 rpm with the engine off, so i guess this is a duff
The NiCd batteries are rechargeable, and so are connected to the power rail that feeds other instruments. When these batteries fail they tend to go short circuit, dragging down the voltage on the rail, and messing up other instruments.
The lithium batteries are not rechargeable, and as a result are not connected to other instruments via the power rail. Their only purpose is to maintain the SI memory if, and only if, the main car battery is disconnected. They also don't have a tendency to short circuit, so the only effect of a failed lithium battery is that SI data is lost if the battery is disconnected.
Over this last weekend I've experienced yet another fault with a lithium type board that I've never seen before (only two green LEDs after reset), and am coming to the conclusion that these boards are best avoided in favour of the NiCd type, whose ONLY fault is battery failure.
Replace the aged batteries on these with NIMH ones (use 2/3 AA size to give more room) and they should be good for many years.
This fault doesn't normally cause any other problems. In use the board works normally.JC1989 wrote:one of the boards does display just 1000 rpm with the engine off,
JC1989
oh k thanks,Replace the aged batteries on these with NIMH ones (use 2/3 AA size to give more room) and they should be good for many years.
is this probably the best suggestion,
in which case is it hard to replace?
would these do the job
http://www.ebay.co.uk/itm/4-2-3-AA-800m ... 2a13fa28e1
i now these have tabs on the side, but woud the work? ( just a case of removing old and replacing with these, would they be the same size as the old ones>?
cheers for you time
Jack
These would work as replacements for the correct type of SI board, but can't be used as replacements on boards that use lithium batteries. The two types of board use different circuitry.
JC1989
s this the rite board for those batteries cheers-
The NiCd batteries are full AA sized, so that looks like a lithium celled board.
