Early M20 management upgrade??
jimf
I've just got my 1987 325i and have learned that fitting the later management system maybe a good idea. Is this a difficult job or is it all plug and play?
- **BANNED**
It's not quite straight forward...easier if you have a donor engine to compare and strip.
You need the engine loom and all of the bits attached(as some connectors are different)along with the toothed wheel attached to the front pulley and the bracket close by that the crank sensor attaches to.The way that the rev counter receives it's signal is different as well,but this is well documented now.
Youth is wasted on the young.
Ant
- Retired Team Member
nothing wrong with keeping the M1.1 as long as it works imho
Email FTW
