Flickering lights & failed central locking!
ProfDMW
Post Mon Feb 07, 2005 12:05 pm
Back again for more assistance from the 'knowledge'!
Two faults at the moment - the central locking on my 1991 touring has stopped working. Doesn't operate via the alarm or via tha key in the door. Makes a strange 'quiet' noise, but no action. Is this the famous 'failing' switch fault? or worse?
Fault number two: I've mentioned this on the forum before, mainly with regard to 'flickering dash illumination'. The fault hasn't got worse, but driving late a night recently, I noticed that the headlights were flickering as well - so I guess this is effecting all the electrics. Although everything works ok? I'm technically feeble, so please help me out?
Cheers ProfDMW :oops:
Post Tue Feb 08, 2005 1:07 am
Flickering headlamps is probably a failing regulator/ brush pack on the altenator.
Central locking problem. See if there is 12V+ at the red/black wire going into the locking ECU. Check with a lamp, not a meter. If this is missing then a pin in the driver's door plug and socket is probably corroded.
There are two red/black wires going into the door pillar socket. Remove them both from the socket and join them together.
ProfDMW
Post Wed Feb 09, 2005 10:51 am
Thanks for the tips! Much appreciated - I shall have a look at the CL fault at the weekend ('cause its driving me insane at the mo!)
Cheers, ProfDMW
