Need help finding this intake boot
boomerm20
Post Sun Sep 11, 2011 1:34 am
My car is a German-spec '89 325 sport.I'm currently experiencing a vacuum leak and would like to replace the intake boot,but I'm not having any luck locating this part.Any help will be appreciated.
Rtaylor2208
Post Sun Sep 11, 2011 7:38 am
You can still get these at the BMW dealers in the UK, have you tried in the US
Post Sun Sep 11, 2011 10:12 am
This is a late type intake boot without the branch for the servo. There was a thread on the different boots a couple of days ago.
boomerm20
Post Sun Sep 11, 2011 12:57 pm
Thanks for the info guys.Realoem doesn't have this part listed for any e30s,but I was able to get the part number from intake boots for sale on ebay.
Post Sun Sep 11, 2011 2:34 pm
I can assure you that the boot is in the ETK, listed under fuel preparation.
sibear
Post Sun Sep 11, 2011 3:43 pm
Have you tried schmiedmann (schmiedmann.com)?
Post Sun Sep 11, 2011 5:54 pm
Item 8, part number 13711726325 used from jan '89.
boomerm20
Post Sun Sep 11, 2011 6:54 pm
[quote="bss325i"]Item 8, part number 13711726325 used from jan '89.
This is the only boot I could find on realoem,but I found the correct one for my car on ebay.
boomerm20
Post Sun Sep 11, 2011 7:02 pm
bss325i wrote:Item 8, part number 13711726325 used from jan '89.
My car's intake boot only has one port,but that part is not listed on realoem.I found the correct one for my car on ebay,thanks.
http://cgi.ebay.com/ebaymotors/_W0QQcmd ... MEWAXQ3aIT
TPS
Post Sun Sep 11, 2011 7:06 pm
I might have this Boot in my Garage, I'll look later.
boomerm20
Post Sun Sep 11, 2011 7:17 pm
TPS wrote:I might have this Boot in my Garage, I'll look later.
Thanks TPS ,but I need one ASAP because my car is running extremely rich.So I'm ordering one from the dealer and hopefully will have it by Wednesday.
Post Sun Sep 11, 2011 9:40 pm
Ignore the diagram, the part number listed is for a single outlet boot as fitted to 325i's from jan '89. My car is the same and i have replaced it using that part number.
By the way, if your boot is split it will cause the engine to run lean not rich as it will be sucking in unmetered air after the AFM.
Check the blue temp sensor first if your car is running rich.
boomerm20
Post Sun Sep 11, 2011 9:57 pm
Excellent info,thanks for the clarification.I actually ordered the boot using that part number,and didn't notice the extra port until the boot got shipped.
