slightly noisy gearbox main shaft
325cabman
I've got an M20 325 manual with a slight gearbox rumble when warm. I'm told it may be the main shaft. The noise goes away when clutch is depressed but no noise at all when running from cold. My question is: can I put a thicker oil in the gearbox? and what would you reccomend? And what sort of price to replace bearings?
IIRC the Getrag 325i boxes are quite well known for a bit of "chatter"
Just change the oil with good quality stuff - if its only a slight noise it will run like that for ages without any issues - I'd only be doing a rebuild if it gets worse or you start getting crunching issues.
325cabman
Thanks Rob,
I changed the oil 12 months ago and only done about 1500mls since, it is only a very slight knock and only if the tickover gets a little lumpy. Maybe I need to sort the tickover!
