Advice on which diff??
ross2009
Post Mon Sep 05, 2011 8:03 am
Guys I've done about 500 miles on my new build now and it feels a tad slow in the lower rev ranges mean like a 1.4 polo can pull away from me lol
Anyway the diff I've got is a 3.25 LSD I know it's low geared but was wondering what people think would be the best ratio?
Thanks in advance
Turbo M20
v8 project 6.0 twin turbo
Post Mon Sep 05, 2011 9:29 am
With a 3.25 diff it might be worth considering an E36 gearbox, if it will fit whatever engine you have. This will give the equivalent of a 4.01 diff with an E30 box.
ross2009
Post Mon Sep 05, 2011 9:38 am
Sorry forgot to mention it's a m20 2.5 I don't mind changing diffs e36 gearbox won't fit an m20 will it Brian
Turbo M20
Post Mon Sep 05, 2011 9:45 am
It will if you leave the M52B28 still attached to it!
Your diff. will be a bit to much the other way with an E36 box. You need a diff. in the middle - 3.64 or 3.76
ross2009
Post Mon Sep 05, 2011 9:48 am
Lol ha nice one
Yeah I really don't know which would be best I think I'd rather have it a little quicker of the line that top end so maybe 3.76
Turbo M20
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Sep 05, 2011 10:04 am
The best for a 325 is a 3.64 apparently. It gives the right compromise between acceleration and economy. You could go one up to a 3.73 if you want better acceleration.
But a 3.25 is a diesel diff, isn't it?
**BANNED**
Post Mon Sep 05, 2011 10:12 am
At a guess,your 3.25 is giving about 80mph at 3000rpm?
You will need about 250bhp to cope with that....
3.64 is 73mph at 3000rpm
4.1 is 65mph at 3000rpm.
You really need a medium case diff with a 2.5,one with 8 bolts holding the rear cover on.
Youth is wasted on the young.
ross2009
Post Mon Sep 05, 2011 10:30 am
Erm I think it's doing about 70 80 at 3000rpm so your about right well it's going to be turboed and about 350 bhp so will the 3.25 ratio be ok then of should I still go about 3.64 or 3.76
Turbo M20
ross2009
Post Mon Sep 05, 2011 10:32 am
Grrrmachine wrote:The best for a 325 is a 3.64 apparently. It gives the right compromise between acceleration and economy. You could go one up to a 3.73 if you want better acceleration.
The 3.25 is the e30m3 diff I believe
Turbo M20
**BANNED**
Post Mon Sep 05, 2011 11:53 am
ross2009 wrote:Erm I think it's doing about 70 80 at 3000rpm so your about right well it's going to be turboed and about 350 bhp so will the 3.25 ratio be ok then of should I still go about 3.64 or 3.76
Diffs are reasonably easy to swap,I would look around for a 3.64 or a 3.73 and buy what ever comes up first,but hang onto the 3.25 for when you fit the turbo.The other will re-sell easily for the same cash that you paid.
Going from recent experience,if you are fitting a diff laid on your arse under a car on axle stands,check it's mounting bolts every six months!
ross2009
Post Mon Sep 05, 2011 11:57 am
ive done many mate dont worry about that lol
so you think that 3.25 will be good for when its turboed ?
just thinking as i will prob have about 3000 - 4000 rpm of lag so the bottom rev ranges still wont be affected
Turbo M20
**BANNED**
Post Mon Sep 05, 2011 12:04 pm
Guess it will depend on how quickly the turbo spools up.....my only experience of turbo's is via HGV's,come on boost at 900rpm and all done by 1700rpm!
ross2009
Post Mon Sep 05, 2011 12:09 pm
it will be between 3 and 4 k so hence why i really wanted some thing higher geared for the lower rev range
this car is only built for a toy its not a daily driver im not worry about fuel comsumption or motor way miles etc so i think i may go for like you mentioned a 3.64 or a 3.76 :)
Turbo M20
Post Mon Sep 05, 2011 1:30 pm
ross2009
Post Mon Sep 05, 2011 1:32 pm
i was looking at that one dan but he wont post it and its abit far to go just to pick it up from me but would be perfect
Turbo M20
