Auto gearbox service?
sajad09
Post Sun Sep 04, 2011 10:20 pm
My e30 is a 1993 325i with switchable auto gearbox,
I want to give the whole car a good service, just wandering if a gearbox service is somthing that i can do my self as a diy job?
I have basic tools and knowledge..
Also if a can do it myself whats the best way to do it?
Whats the best oil to use and are there any filters in the box?
Sorry to be a pain but iv never done it before.
Thanks saj
James90
Post Mon Oct 03, 2011 1:37 pm
Not had a go at this myself yet but I have the parts ready.
There are 2 gaskets and a filter that you need (and oil obv.!)
Fairly easy to do - I found instructions from a google search.
If you need part numbers I may be able to help you out later - let me know.
From BMW the kit is around £67. I think it is around £14 at ECP but is missing a gasket.
'88 325i Auto Chromie Cabriolet in Alpine White
sajad09
Post Mon Oct 03, 2011 1:49 pm
Cheers. Thanks for the heads up. Will atempt this soon. Will let u know how i get on
mrLEE30
Post Wed Oct 05, 2011 6:25 am
easy to do the job but access is biggest issue, remove the drain pipe from oil pan allow to drain, remove and lower oil pan to drain remainig oil (about 5 litres max) remove the oil pan and clean, using a Torx drive remove the oil filter, replace oil filter and o ring, refit oil pan/fill tube with new gasket. lower car to level and fill, run for a few minutes selecting all gears, check oil level refill if necessary.
.. on a lift or a pit its a half hour job, otherwise take it to a garage....do NOT do it with a jack, at a MINIMUM you should have the front of the car supported on TWO jackstands or less desirable on car ramps.
