battery problems
christo
Hi guys i am looking for help with my 318i cabrio the problem is that the battery goes flat for no knowing reason i drove it 20miles yesterday went shopping and when i went to start it the battery was just flat,now i checked the alteranor and the battery is new so where can the problem be?? cheers christo.
Charge the battery, and reconnect it with a milliamp meter between the battery negative terminal and the battery earth lead, to see what the quiescent current is, and to confirm this is the problem. Remove fuses one at a time, until you find where the current is going.
Normal quiescent current for an E30 is around 30mA, but varies depending on equipment fitted.
Lock your car up and look through the window, are your electric window switches lit up still ?
