Econometer playing up-ideas?
rover-2000
Post Sun Aug 28, 2011 7:08 am
Guys
The Econometer in our new Touring is behaving strangely! It only registers zero or maximum, swinging between the two usually when changing gear..... :?
I did a search and I see that problems usually involve the other instruments too, but everything else is fine. Any ideas as to what might be the problem?
Many thanks.
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
Post Sun Aug 28, 2011 7:20 am
Not heard of this problem before - it usually either works or it doesnt !
Have you tried removing the cluster and checking the multiplug connection on the back ?
Welcome anyway - where in Walsall are you ? I'm near Cannock and there are quite a few zoners locally if you get stuck with anything :D
groovylee
Post Sun Aug 28, 2011 7:26 am
mine does this too, but it is coupledwith a non working speedo. plus, mine tends to fluctuate coming on and off the throttle :mad:
Post Sun Aug 28, 2011 7:36 am
http://www.e30zone.net/modules.php?name ... econometer
Throttle Position switch clean out/reset/refurb should help by the look of it - even if it doesnt cure your econometer problem its worth doing !
rover-2000
Post Sun Aug 28, 2011 9:23 am
Thanks guys-will look into it-where is the trottle position switch and what does it look like?? I'm just off the Sutton Road in Walsall-near the "Longhorn" pub.
Kind regards
John
1989 320i Touring
Post Sun Aug 28, 2011 10:27 am
Econometer has lost its road speed signal. If the speedo. is working, then there's an internal problem in the cluster.
I've come across just one case of this, and found burnt components on both the speedo. daughter circuit board and the SI board.
At this point i binned the lot, and fitted a replacement cluster.
rover-2000
Post Sun Aug 28, 2011 10:44 am
Then I think I'll leave it until something else packs up!
Thanks.
Kind regards
John
1989 320i Touring
e30-EVN
Post Sun Aug 28, 2011 10:46 am
mine was doing this the other day..... turns out the speed sensor connection on my dif was loose.... sorted that and been working fine since 8)
Post Sun Aug 28, 2011 10:51 am
Your needle swings from side to side as you describe because when you have your foot on the accelerator you are using fuel, and, because the gauge thinks you are not moving, it reads zero MPG. When you change gear, and lift off the throttle, the over run fuel cut off briefly engages, and you are using no fuel. The gauge reacts to this by correctly swinging to 50+ MPG.
e30-EVN
Post Sun Aug 28, 2011 10:55 am
ive had to stuff a little piece of card in the side of my speed sensor to sort of jam it in so it stays in... the clip is snapped off the sensor so it was loose
can i buy a new sensor, and is it a case of just cutting the old one off and joining the new 1 up??
both my speedo and mpg meter work fine now but since being under there to investigate i cant leave it knowing the clip is snapped lol
Post Sun Aug 28, 2011 10:59 am
e30-dk wrote:ive had to stuff a little piece of card in the side of my speed sensor to sort of jam it in so it stays in... the clip is snapped off the sensor so it was loose
Your problem isn't really applicable to the OP, because in your case the basic problem is the speedo drive. The OP says that his speedo works fine.
e30-EVN
Post Sun Aug 28, 2011 11:04 am
oops sorry about that mate, i miss read op's post :o: :o:
Post Sun Aug 28, 2011 5:08 pm
rover-2000 wrote:Thanks guys-will look into it-where is the trottle position switch and what does it look like?? I'm just off the Sutton Road in Walsall-near the "Longhorn" pub.
Throttle position switch ( TPS ) is located on the underside of the throttle body - you need to remove the throttle body to get at it ( order a new gasket from BMW first - they're pennies )
if you plan on keeping the car you may find this book invaluable :
It includes an excellent guide on how to refurb the TPS amongst other things.
the author is a regular contributor on this forum.
Use www.realoem.com to find the correct part numbers for any bits you need
I know the sutton road/longhorn very well - used to live just up the road in Streetly :D
rover-2000
Post Sun Aug 28, 2011 5:43 pm
Thanks-we do intend to keep it long term, so will invest in one of those books. What are the Bentley manuals like? The Haynes seems pretty hopeless as usual!
Kind regards
John
1989 320i Touring
