Recently had the fan fixed on my iS (well replaced I should say) and took it out for a spin today.
Dont think there is anything wrong with the temp gauge as it goes up when stationary or driving slow and cools down when I speed up
BUT I am not sure if I am just driving it too hard (often between 3.5 and 6 rpm) and the temp guage is creeping past half way (it did not use to do it!) is this is to be expected or do I have a more serious cooling problem?
I know there could be loads wrong but I do make sure the car is serviced and looked after but I figured there might be some checks I could.
I did bring it back home and opened the bonet, it did cool down but thats kinda the rules of physics...!
Driving too hard or something else...
Jimbob
I only notice my temp guage to go over halfway when there's a lack of cooling fluid, keep it topped up and it goes halfway at the worst of times.
I take it you mean you had the viscous coupling replaced?
Hyperion
yeah i think you should check the fluid levels every morning, if you notice a drop in level, it could be the hoses expanding with the heat and losing liquid. i had a problem aswell. one of the hoses had a crack taht only showed up when i drove my car hard and long.
koos
