Can a cambelt slip, car wont start
PG325
Post Sun Aug 21, 2011 5:01 pm
Started the car yesterday, all fine.
Went to go out today and the car won't start, it's getting fuel and it sparking, eventually got it started but it sounds really bad.
I've taken the cam belt cover off and can see that whilst the camshaft lines up the lower damper sprocket is not at TDC.
Have a look at the pics, I would say the crank is 15 degrees past the mark on the cover plate, what would cause a belt to slip.
The car was running fine up to starting today and has only covered 3000 miles since a new belt was fitted last summer, the belt is still tight.
I haven't taken the belt off yet but I guess loosen, remove and reset the crank TDC, then refit and see if any damage has been caused.
ImageImage[/img]
craigieeb
Post Sun Aug 21, 2011 5:46 pm
Whip the rocker cover off and see if all the rockers are still intact
PG325
Post Sun Aug 21, 2011 5:53 pm
Still intact and all moving fine when turning over by hand, I did notice some moved slightly on the rocker shaft, is this ok?
Post Sun Aug 21, 2011 7:25 pm
Slack belts can and do jump the odd tooth.
Question is, why is it slack?
Collapsed tensioner shaft? (Usually throws the belt against the front cover, and wears it narrow).
Someone didn't lock off the tensioner, and it's still being tensioned by the spring?
BTW, don't reuse a belt.
PG325
Post Sun Aug 21, 2011 7:36 pm
The belt appears and feel tensioned, all the bits were new last year, tensioner, belt, spring.
I guess I'm gonna realign, fit a new belt and see if any damage has been caused.
PG325
Post Sat Aug 27, 2011 3:27 pm
Well I replaced the belt and tensioner today, fitted it all back up and turned the key, she's back running like a dream, luckily the belt seems to have only jumped a couple of teeth, I think this is what saved any potential damage to the valves.
Post Sat Aug 27, 2011 8:22 pm
How did you tension the new belt?
Post Sat Aug 27, 2011 8:40 pm
Was it a genuine Belt?
PG325
Post Sun Aug 28, 2011 7:44 am
I fitted a new Continental Contitech belt from ECP with new tensioner, it was tensioned using a new spring and pin from BMW.
adit
Post Sun Aug 28, 2011 8:44 am
well done Paul, glads all's well now :wink:
[quote="bss325i"]
Post Sun Aug 28, 2011 10:32 am
PG325 wrote:I fitted a new Continental Contitech belt from ECP with new tensioner, it was tensioned using a new spring and pin from BMW.
What I'm trying to establish is did you then tighten both bolts? I've no idea on your level of mechanical skills or knowledge from here, but you wouldn't be the first to think that the belt is continuously tensioned by the spring.
PG325
Post Sun Aug 28, 2011 10:34 am
Yes definitely tightened both tension bolts as I did 3000 miles ago, I can't understand why the first one jumped, but all seems fine, going out for a test drive today (if the sun remains out!).
