On my 1984 323 it originally had an external fuel Pump that sits down on the N/S sill beside the petrol tank.
However due to the bracket holding the pump in place rusting away and is now NLA, I have decided to fit an in tank pump.
My query is this.
For the external pump on the N/S the +12V is a Green/ Violet 1.5mm feed.
Checking on the O/S there is the connector for the Sender/Brake pad wear/ Speedo.
In this connector on the car side there is also a 1.5mm Green / Violet feed, which on the "connecting loom" currently doesn't have a corresponding wire.
Is this the same feed? ( Pre wired for an in tank pump )
I have tested it and there is +12 V with the ignition.
What I do know is that the +12V feed for the pump is supplied from the fuel pump relay.
I want to ensure that this is indeed coming from the relay and not some other source.
I am not exactly sure where this relay is, can someone point me in the right direction.
If it is
From Realoem it appears that the loom changed over in 87?
I have another loom from a later car which has the Green / Violet however the connector is a different shape
My Car side of the connector is a white plug that is 3x3 where as the loom I have is black and I think 4x2.
Is there a post 87 loom that will plug straight in. Or will I have to cut /solder to get this to work.
