Leak from sump area
timidtim
Your M40 has an upper and lower sump, and yes, the bolts do work loose, especially where the upper sump joins the block, and have been known to fall right out. A couple of these bolts are inside the sump, and can only be reached by removing the lower sump. It's quite common to find one or more of these bolts lying in the lower sump!!
You can always try your luck at just tightening everything up, but as above, you'll have to remove the lower sump to do so.
Lower sump is dead easy to remove, and that gives access to the oil pick up pipe, to enable you to remove the upper sump. Far easier to change than on a M20!
