E30 Brakes Questions
Darrenr
Post Sun Aug 14, 2011 8:24 pm
Hiya This is my first post due to being a new E30 owner! so any help and advise would be great!
Ive got stright in the deep by converting a 316 in to a M60b30 which ive done now for a drift car my problem is after installing a hydralic handbrake then ive gone to bleed the brakes as normal i get fluid to the back calipers fine but then hydro goes solid and back brakes lock on, i can only release the back brakes by releasing the fluid out.
but then i go to bleed the front brakes and theres no fluid what so ever, ive tryed manual pump and easy bleed throught the airline, I took the brake pipes out of the master cylinder and theres nothing coming out of the M/C
Im just wondering if anyone has had this problem in the past.
Many thanks
e301988325i
Post Mon Aug 15, 2011 5:47 pm
Sounds like your hydraulic handbrake is set wrong and not allowing the pressure to drop after the brakes have been applied.
I said:
e30topless said:
lock the wife in there
