TDC Valve positions
bluff467
I am going to put my cylinder head back on to the engine today, m20b25, but I just want to make sure that the valve positions are right before I do so. No 1 and 6 pistons are up, so should the valves for no 1 and 6 be closed when I put the cylinder head back on?
Life is short so enjoy it while it lasts. Buy an E30!
E30_Crazy
Just turn the crank about 25-30* clockwise and all pistons should be at some level of mid-bore. Then get the head on, and tightened down. Turn the cam gear until the notch and line are inline (TDC for cam) and then turn the crank back the 25-30* to TDC, and it will be all lined up for the cam belt.
One set or the other should be partly open.bluff467 wrote:should the valves for no 1 and 6 be closed when I put the cylinder head back on?
As said above, never put a head on with any piston completely up.
bluff467
When I line the marks up on the cam does it matter which valves are open and which are close, or are the valves automatically in the right sequence when the marks are lines up?
HairyScreech
the timing marks should be tdc number one cylinder, thus if you put both the cam and crank to there timing marks you cant really get it wrong.
