Next job on my cab is to find out what's making the metal scraping noise from the rear of my 325 cab. It's a difficult noise to describe, but I can most liken it to the sound of two metal discs rotating against each other. It's definitely coming from the rear of my car and seems speed related, so I'm guessing it's the diff - or could it be the fuel pump?
Anyone had this before?
Metal scraping noise from rear
PeteE30Tourer
Back behind an M20, but now I can hear it better.
Bristol_Jer
It would be worth checking that the disc backplates aren't touching the discs, long shot but an easy fix
age
- Formerly twist316
This might sound off the wall but did your exhaust bracket fall off and is stuck on the back wheel??? Might sound crazy but i've seen it on more than one e30
DHFiS
Rusty diff case rubbing on output flange?
- **BANNED**
My money is on backplate/disc contact!
Eventually the disc will rub a hole in it,then it stops squeaking.....
Could also be a seized caliper,causing a pad to eliminate it's self against the disc and is now down to the metal....
Youth is wasted on the young.
