Ticka-ticka-ticka-ticka-ticka...
Omi
Witty custom rank.
Post Sat Feb 05, 2005 8:26 am
Seems to be the noise of the month on my car. :?
When cold, I'm getting a lot of injector tick... Reckon having them ultasonically cleaned will resolve? Can't just stick M30 injectors on an iS, because us 4-pot boys have special (read awkward) injectors.
Also, I've got the strangest indicator problem.
When I smacked the car off the kerb, it was like I broke the rear nearside indicator, fast relay noise and the rear bulb wasn't firing... Swapped the bulb out with the other side and it's beeen fine since. - Until the other side (offside) stopped working yesterday... Was working, then it started doing the fast relay tick with the dashboard repeater flashing correctly. Now all I get is relay noise. - No flashing green on the dash, and none of the right indicators fire at all. :(
Is it something obvious like a fuse? - It's cold outside and I'm stuck at work all day every day at the minute, so I thought I'd pick the collective Zone Brain before opening my bonnet!
...or is it?
Omi
Witty custom rank.
Post Sat Feb 05, 2005 2:42 pm
Perhaps if I asked about putting a 6-pot engine in I'd get more support? :'(
...or is it?
Post Sat Feb 05, 2005 11:52 pm
I'm not predujiced against our weaker engined brothers.
Front indicators can stop working or become intermittent after a shock, because of a not to clever design of front lampholder. Cheap lamps which corrode can be part of the problem as well.
Lamps with blown filaments can sometimes temporarily repair themselves as well if the broken ends touch with vibration from the car's motion.
Omi
Witty custom rank.
Post Sun Feb 06, 2005 6:55 pm
UPDATE: I've found that all 6 indicators flash ok if you switch on hazard lights, and if you grab the indicator stalk then twist it really hard then the indicators work ok and the light even come on the dashboard.
So it looks like a faulty indicator stalk/switch, agree?
...or is it?
billgatese30
Post Sun Feb 06, 2005 6:57 pm
sounds like you've hit the nail on the head there mate.
i was going to suggest that the other day but i knew you would work it out :cool:
how is the speeding thing going, any news
Ant
Retired Team Member
Retired Team Member
Post Sun Feb 06, 2005 6:59 pm
seems logical dude, how did you discover that then??
I know utter frustration :lol:
Andy335Touring
Post Sun Feb 06, 2005 8:13 pm
billgatese30
Post Sun Feb 06, 2005 8:16 pm
richy 325 is breaking a car...he will have a stalk if you ask him
