Wing Mirrors Not Working
tom325sport
Post Fri Mar 25, 2011 9:13 am
I've followed this step below...
"For the mirrors, first check for power (with a 12V lamp) at fuse 19, with the ignition on. (Touch the fuse wire in the fuse with the test lamp lead). Next, pull out the mirror switch and check for 12V on the green/white wire.
If there's power at the fuse, but not on the switch, then door pillar plug again."
There is power at the fuse and on the green/white wire. I'm sure my car should have had colour coded mirrors as it is a 1993 convertible, but it has black ones?
Any suggestions to where to look now?
Gouki
Post Fri Mar 25, 2011 2:22 pm
Might be your mirror switch? I had this problem on mine, tested wires power was present but none were moving so swapped switch over and it works again.
clipper
Post Fri Mar 25, 2011 2:25 pm
First cause of mirrors not working:
You're a vampire !
Sorry. :o:
tom325sport
Post Fri Mar 25, 2011 3:35 pm
I've changed the mirror switch twice now but to no avail! Maybe both were faulty?
beemerbird
Post Fri Mar 25, 2011 4:43 pm
Have you removed the mirror glass to check the wires are connected behind it?
tom325sport
Post Fri Mar 25, 2011 9:49 pm
beemerbird wrote:Have you removed the mirror glass to check the wires are connected behind it?
I've not no, but will try this...thanks.
tom325sport
Post Sun Mar 11, 2012 7:34 pm
OK so I'm now sorting these bits out now my car is back on the road - Wing mirror time!
As before I've done this:
There is power at fuse 19 and on the green/white wire when ignition on.
The mirrors are all connected!
I've tried another switch!
2 sets of mirrors have been used!
Is this the only thing it could be - THE SWITCH?
Sanchez
Post Sun Mar 11, 2012 7:43 pm
Is there a local zoner who has working mirrors and swap the switches around so you can test them.
My mirrors dont work but the fuse keeps popping so different problem.
Post Sun Mar 11, 2012 11:15 pm
tom325sport wrote: There is power at fuse 19 and on the green/white wire when ignition on.
Tested how?
tom325sport
Post Mon Mar 12, 2012 10:33 am
Brian - Tested with a lamp. Shall I test with a multimeter?
Post Mon Mar 12, 2012 12:31 pm
No, lamp is the correct way. Meter would give false and meaningless results.
There's not a lot to check for the driver's side, if you're certain power is getting there.
Fit the switch and check for power at the brown and blue/white wires at the mirror plug. There should be 12 volts across these two wires all the time the ignition is on and the mirror switch is in its 'off' position. Check that the brown wire here is actually earthed.
tom325sport
Post Tue Mar 13, 2012 4:35 pm
Thanks for all the advise! All sorted now...............It was the pesky switch! Strange how 3 off them didn't work.
