I would like to retrofit heated front seats. I have the kit (BMW one) but my question is how to fit the elements under the cover. Do these have to be secured by glueing the element strips to the base.
If they are loosely laid in time they could move under the cover.
heated seats
They are loosely lain & not glued
Current E30 325i, E63 630is.
killerwelshman
I recently retrofited heated seats into my cabby using the BMW loom and switches. If you encounter any problems give me a shout
. The hardest part was running the cables under the carpet as it's not that flexible!
did you get the kit from BMW?
e301988325i
About £150 for the elements, £40 for each switch, £80 for the loom. orasmith88 wrote:is the kit available from bmw? how much?
http://cgi.ebay.co.uk/MSH50-Waeco-Heate ... 5189224f0e
and a bit extra but not neccessary
http://cgi.ebay.co.uk/WAECO-HEATED-SEAT ... 5640012749
http://www.e30zone.net/modules.php?name ... ated+seats
I said:
e30topless said:
lock the wife in there
Thats what i was aftere301988325i wrote:About £150 for the elements, £40 for each switch, £80 for the loom. orasmith88 wrote:is the kit available from bmw? how much?
Waeco actually made the oem kits!!!
There is a way to get the waeco loom to work with the oem switches as I've never been a fan of the cheap looking switches they supply!
I have recently fitted the waeco kit, and am absolutely loving it! just need to get hold of the oem switches!
If you haveany questions let me know! also try searching on here as a few zoners have fitted them!
Tee
Tee
