325 touring
front shocker collars
gcorky
- Boost Junkie
front shocker collars ,are they a bas***d to get out normally or ok???
325 touring
325 touring
littlejim
Ive only done one set and they come undone quite easy
gcorky
- Boost Junkie
what did ye remove the collars with?
Templ8e30
I made a special tool that locates into the 4 holes on top of the collar and has a 1/2" square drive filed into it. However you could resort to using a big pair of stilsons !
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
- Homo Hair
big pair of stilsons... vice and a scaffold pole should do it..
littlejim
i used a big pair of stilsons and a vice,but don't do the vice up too tight and crush the outer tube, you wil have trouble getting the old shock out.
Demlotcrew
Okay these guys have some good advice but if i were you i would do what i do!
Get the strut off, then bolt the strut to a spare wheel, lay the outer part of the wheel on the floor, ask someone to stand on the wheel while you get the collar nut off!
This way you dont damage any part of the Strut and you dont risk messing up the caster/camber.
Andrew
Andrew
gcorky
- Boost Junkie
thanx all
Boots_Walker
i had one that i couldnt get to budge at all, introduced it to our old friend heat and then it came straight off
