first - to remove the OBC i take out the computer itself, control unit, gong, dash loom and yellow temp sender from behind foglight. anything else? temp sender wiring? relays/fuses?
second - apart from foglight units and the 2 button switch is anything else needed to fit to a non-foglight facelift E30? relay/fuses/wiring?
Third - it has lec sunroof which is a good thing as my own sunroof handle just snapped
i'm asking because my base spec 316 only has one less relay than this car, which has both lec sunroof and fogs...
thanks all.
