hunting on cold start
rash_1
Thu Sep 30, 2010 11:22 am
hi, when i start my 325 up from cold it seems to be hunting for about 2-3 mins but once warmed up its fine, i've changed the blue temp sensor is there anything else i can do.
many thanks
Thu Sep 30, 2010 1:21 pm
Drive it would be one solution. Engines aren't designed to be idled for three minutes after start up.
It's probably hunting because of an incorrect mixture, usually weak, for one or a combination of several reasons.
Injectors long overdue for a service? Pattern 'blue' sensor' not 'tracking' resistance against temperature as intended, minor air leaks, etc.
rash_1
Fri Oct 01, 2010 11:18 am
cheers Brian, i don't think i've ever done the injectors, i think i'll try that next
