Benefits of a intercooler on a turbo car
sweep
Mon Aug 30, 2010 10:00 pm
As above what would be the benefits of fitting a intercooler?
BornToBeE30
Mon Aug 30, 2010 10:05 pm
With air passing through the intercooler after being recycled from the turbo it cools the flow of air being forced into the intake manifold, making more for horse's from the engine.
The reason for more hp's is when the air leaves the turbo it has expanded due to the heat and the intake cant take the high volumes for this reason, cooling it down with an intercooler in the loop means you can force a bigger volume of air into the intake meaning a larger amount of air and fuel will be combusted per cycle in the engine, creating an increase in engine power.
Mon Aug 30, 2010 10:10 pm
Cus it stiks out tha bumper innit :)
Mon Aug 30, 2010 10:20 pm
DanThe wrote:Cus it stiks out tha bumper innit :)
:chuckle:
e30shed
Mon Aug 30, 2010 10:27 pm
Innit :puke:
1988 325i SE h/c
Black sport leather, mtec suspension -60mm, LSD, tech1 steering wheel, chipped motronic 1.3 & numerous scabby bits R.I.P
2003 320d ES pov R.I.P Now in swirlflap heaven.
2001 330i SE MV1's
1987 M535i Alpine white
BornToBeE30
Mon Aug 30, 2010 10:58 pm
:lol:
That's wack but I bet its quick off the mark.
333i
Tue Aug 31, 2010 12:20 am
because cooler air is denser and therefore the cooler the air the more bhp you can make but fit a too large ic then you get huge turbo lag
TouringTash
Tue Aug 31, 2010 12:43 am
Innit :puke:
is that an a4 or a6???
318i Touring
Kos
Tue Aug 31, 2010 12:51 am
it is an A bortion :D
www.pukardesigns.com
IG Pukar.Designs
TouringTash
Tue Aug 31, 2010 12:53 am
:lol:
318i Touring
Kos
Tue Aug 31, 2010 12:59 am
the audi logo needs to be changed to baby ....................
the turbo does the job of it sucking the unwanted out, beats using a wire coat hanger to hook it out :D
ok, i should behave now. no more sick jokes
IG Pukar.Designs
TouringTash
Tue Aug 31, 2010 1:13 am
just what is on you mind.
Go on you can tell us winkeye
318i Touring
Kos
Tue Aug 31, 2010 1:19 am
nothing at all lol
been there, done that many years ago.
IG Pukar.Designs
srmalek
Tue Aug 31, 2010 1:50 am
heeheheh
HJG-E30
Tue Aug 31, 2010 12:04 pm
As already mentioned, the compressor in the turbocharger compresses the air which significantly increases the temperature. Engines produce more power with colder air (hence 'cold air feed') and colder air is more dense - this being the key word here.
An intercooler can be used within the turbocharger system to cool the compressed air thus increasing the density. This can be of an air to liquid type or air to air type, and obviously must be mounted somewhere where cold air is going to reach it, i.e. no where near any hot part of the engine, which is why intercoolers are often seen at the bottom of the front of the car.
However intecooler efficiency must be good and size must be taken into account for the amount of flow you are expecting / aiming to achieve, otherwise turbolag will be an issue and engine power also affected.
sweep
Tue Aug 31, 2010 8:49 pm
Can a intercooler be retro fitted easly enough?
Theo
Tue Aug 31, 2010 8:59 pm
What non-intercooled turbo car do you have?
sweep
Tue Aug 31, 2010 9:03 pm
Its a 2001 td escort van,the td cars had a intercooler but the vans did not.
Theo
Tue Aug 31, 2010 9:15 pm
Probably a bolt on conversion fitting the parts from the car to the van, get yourself down to the scrapyard!
HJG-E30
Tue Aug 31, 2010 10:06 pm
I was involved in turbocharging a 205GTi once, and we used an intercooler from a BMW diesel and it worked wonders, so as long as you get the size right then you'll be fine
Tue Aug 31, 2010 10:12 pm
sweep wrote:Its a 2001 td escort van,the td cars had a intercooler but the vans did not.
Dont waste you time/money.
Tue Aug 31, 2010 11:14 pm
If you try to make it go faster it will break quicker, thats how the blue oval disease works :)
N00b
Tue Aug 31, 2010 11:17 pm
This^
Tue Aug 31, 2010 11:20 pm
it's the same van i collected your leatherzzz in Baz,
maybe the intercooler will help me collect morsels faster? :D
TouringTash
Wed Sep 01, 2010 2:36 am
a bit of a curve ball but still in the same field, could the a.c. system be rerouted to the air intake?
From reading the above about colder air giving a better bang would this be worth doing or would too much power be lost from running the a.c. to make any gains.
Sorry if this is dumb but an average of 75 to brum and back has wobbled my thinking sponge a bit.
318i Touring
Morat
Wed Sep 01, 2010 9:23 am
Your AC system won't be able to flow enough air for the engine...
TouringTash
Wed Sep 01, 2010 11:25 am
but could it be implemented as an addition?
318i Touring
Morat
Wed Sep 01, 2010 4:29 pm
In theory I suppose you could, but I can't see the gains being worthwhile. AC is great for cooling air below ambient temp, but in relatively small volumes. With an IC you're trying to return air towards ambient temp from maybe 80-90 degrees. You're better off using airflow and a big ole radiator, possibly with a water spray if you're really keen.
stoocake
Wed Sep 01, 2010 4:36 pm
TouringTash wrote:a bit of a curve ball but still in the same field, could the a.c. system be rerouted to the air intake?
Definitly use more power than it would produce. Isn't the rule of thump 1bhp gain for every 10farenheit you lower the intake charge?
octanejunkie
Wed Sep 01, 2010 5:17 pm
Don't waste the effort and money on the van.
Use it on ya bimmer instead.... :idea: :wave:
ross2009
Wed Sep 01, 2010 9:15 pm
Innit :puke:
is that for real lmao :)
stoocake
Wed Sep 01, 2010 10:45 pm
ross2009 wrote:
Innit :puke:
Apparently so - just googled Audi Killer
http://www.dragtimes.com/Audi-S4-Timeslip-3641.html
vogue666
Thu Sep 02, 2010 11:39 am
Its all about air density. Cold air is denser. More air more fuel more bang. :P
