M3 LSD - Big or small case?
Mon Sep 19, 2005 5:23 pm
Just put an M3 diff on my car.. is it a big or small case diff?
Jimbob
Mon Sep 19, 2005 5:40 pm
What size was it in comparison to the one you took off?
E30Adam
Mon Sep 19, 2005 5:41 pm
6 bolts on cover = small
8 bolts on cover = large
Mon Sep 19, 2005 6:53 pm
did they do a small case m3 diff then?!
E30Adam
Mon Sep 19, 2005 7:49 pm
Jhonno wrote:did they do a small case m3 diff then?!
If not then you just answered your original question mate!!
Demlotcrew
Mon Sep 19, 2005 8:07 pm
Only Big case!
A
Tue Sep 20, 2005 12:55 am
thats what confused me.. i didnt think they did but the diff i took off my 316i was exactly the same size as the m3 diff i put on. No messing with prop lengths etc..
Toby_Unna
Boost Junkie
Tue Sep 20, 2005 10:17 am
Dan do as Adam says and count the bolts on the rear cover.
either your 316 had a big case diff on for some reason
or you don't have an m3 LSD
count the bolts and you'll have an answer. 6 bolts small, 8 bolts large.
Tue Sep 20, 2005 2:35 pm
yeah i'll count..
thing is its deffo an LSD and its v long - i can get 50mph in 1st now :lol:
Tue Sep 20, 2005 2:53 pm
Looks like its a small case then... 6 bolts
it had a different speed sensor on the diff, i had to put mine on as it was a different connection
now im confused.. what the hell is it from? it has S3.25 on the tag
M3Compact
Tue Sep 20, 2005 5:43 pm
Jhonno wrote:Looks like its a small case then... 6 bolts
Are you sure Jhonno? 6 bolt diffs are usually low ratio.
This is an 8 bolt, large case diff.
Tue Sep 20, 2005 6:02 pm
my filler holes dont look anything like that...
its deffo v long ratio - 2.5k @ 80mph
just over 50 in 1st gear and 80 in 2nd
M3Compact
Tue Sep 20, 2005 6:03 pm
Jhonno wrote:my filler holes dont look anything like that...
:eek:
Deffo LSD too? :eek:
8)
karlp
Tue Sep 20, 2005 6:13 pm
I have an E30 M3 LSD in my garage with a 3.25 ratio and it is definately large case.
The only difference to a 3.91 I bought from Rearwheel Nick is that the output drive flanges are different. The M3 have a thicker flange.
I can take measurements if you like.
Karl
Tue Sep 20, 2005 6:16 pm
:eek:
8)
deffo an LSD - turn the input and both outputs turn the same way, also checked with car in the air, turn one wheel the other turns the same way.. in neutral
also went down to a local dirt carpark and everytime both rear wheels spun up exactly the same
Tue Sep 20, 2005 6:17 pm
karlp wrote:I have an E30 M3 LSD in my garage with a 3.25 ratio and it is definately large case.
Karl
that would be cool
also any pics of the cover plate?
karlp
Tue Sep 20, 2005 6:23 pm
Just taken 3 pics - how do I post picks or give email.
Karl
Jimbob
Tue Sep 20, 2005 6:26 pm
go to www.imageshack.us - very simple to use mate just go on there and you'll have it hosted in 2 mins, you just need to copy a line for each pic on to the zone and it'll show it ;)
karlp
Tue Sep 20, 2005 6:39 pm
Tue Sep 20, 2005 7:03 pm
Looks different to mine.. give me a couple of mins and i'll put some pics of mine up..
Tue Sep 20, 2005 7:40 pm
Not the best of pics but it was on my phone...
karlp
Tue Sep 20, 2005 7:41 pm
That is not an M3 diff - it looks like a small case .
Notice how it is relatively straight from front to back whereas mine has a bulge.
Karl
Tue Sep 20, 2005 7:46 pm
thats what i thought from looking..
small case is not gonna be up to the task of an S50 really is it?
damn it :(
M3Compact
Tue Sep 20, 2005 8:05 pm
NO :)
Fancy swapping it for one that will be? :wink:
Tue Sep 20, 2005 8:06 pm
YES!!
M3Compact
Tue Sep 20, 2005 9:43 pm
Jhonno wrote:YES!!
What ratio are you looking for?
Tue Sep 20, 2005 10:55 pm
erm... 3.25 or even 3.15
Tue Sep 20, 2005 11:38 pm
Jhonno , i'm guessing that diff you have is out of an early e30 323i dogleg car, hence the tall ratio ?.
jonb
Tue Sep 20, 2005 11:47 pm
sir pete is right, 323i diff. i had one of these on 325i a few years back, before my trading days.
they are as weak as any other small case diff. this lasted about a month. and cost me Ԛ£250. :?
Wed Sep 21, 2005 12:23 am
Ahh.. thank you Pete/Jon :D
At least its rare and working :lol:
Andy335Touring
Wed Sep 21, 2005 12:32 am
Thats a shame as i was mulling over a swap to a 323 3.46 dif for mine, poxy small case difs :x
Is there a big case E30 3.46 ?
http://www.behindmatrix.com/e30/fotost/ ... f00023.htm
Andyboy999
Fri Sep 23, 2005 4:30 pm
323i had the small case diff until about June 1984. After that the big diff came out with the 325e 9Eta) and this is in fact an E28 518 - 528i casing with a different rear cover - it's called the Type 188 and was also used on the lower powered E34's. later 323i, 325i, 325e and M3 all used the big diff.
As for the strength of small diffs, a good analogy is Pacerpete's trousers. They're too small for his arse which is why the greasy crack can often be seen poking over the top. He doesn't have that problem when he wears a dress. winkeye
Fri Sep 23, 2005 5:24 pm
F.A.O Andyboy, the reason my jeans dont fit is because lidl dont do xxxxxfcnt size and as for wearing dresses i wish !, none of them ones you lent me Andy fit ! :)
Andy335Touring
Fri Sep 23, 2005 8:11 pm
Andyboy999 wrote:323i had the small case diff until about June 1984. After that the big diff came out with the 325e 9Eta) and this is in fact an E28 518 - 528i casing with a different rear cover - it's called the Type 188 and was also used on the lower powered E34's. later 323i, 325i, 325e and M3 all used the big diff.
Cheers for the info Andrew :thumb:
Could i combine the parts from an open 3.46 dif with the LSD unit from my shagged M3 dif to give me a 3.46 LSD dif ?
It's good to see the return of the Andy/Pete banter,such a good laugh ! :cool:
Pete, did you get my PM ?
Andyboy999
Fri Sep 23, 2005 11:50 pm
pacerpete wrote:F.A.O Andyboy, the reason my jeans dont fit is because
......he hasn't bought any new ones since he started to restore a Triumph Spitfire in the mid eighties. Apparently it's a Man thing. A bit like breaking metal bumper 325i Sports! :chainsaw:
