Can an iS owner be Dr. Goodbloke and tell me how many rubber hangers there are holding on the rear box? Mine is banging against the body, and offset to one side so I suspect there could be one missing, it's irritating and stressful and I'm running out of valiums.
Cheers,
Neil
318is exhaust help
Geeman
Mine has two dude...
tomstickland
Two big clamps holding the back box on on mine, plus some smaller O ring rubbers holding the pipe on near the fuel tank.
TheDutch
Geeman does yours have two metal straps holding it on too?
Edit : yours does actually look like this (unlike mine) :
I've got green but not red.
N
N
Kedge
tomstickland
Both E30's I've had had both of those straps fitted.
ouch
i had 2 on mine aswell the only e30 that has 1 is a 316 or 318 the is has 2 becouse the rear box is so hevy
Geeman
Yeah, I had two clamps on mine.
Got a whole rear exhaust section sat here with both clamps... if anyone wants one...
TheDutch
What sort is it Geeman? Did you remove it to make way for a performance exhaust or something?
N
N
Geeman
It's just a standard exhaust. It's hardly had any use and is in really good condition. I removed it to put a stainless system on that was less restrictive as it's only used on the track (until I made it road legal and had some fun with it!)
Got pics if you want them...
Giles.
Giles.
TheDutch
Might be interested in that... do you know what brand it is? Let me know how much you'd want for it as I'll be needing one eventually
Cheers,
N
Cheers,
N
Geeman
