Shorting prop
ed325i
Post Fri Sep 09, 2005 7:28 pm
Hi, Has anyone had a prop shortend? where did you use and how much did it cost ? Need info so I can work out how much I need to do M30 conversion.
ED
Andy335Touring
Post Fri Sep 09, 2005 8:00 pm
Between me and Toby we think you can use an E30 M3 prop with out chopping it with the e30.de mounts. Just depends on what engine position you settle for ?
At the time of doing my conversion i didn't know that the M3 prop would fit so i had the front section of the E34 M30 prop welded to the rear section of the E30 325 prop at http://www.reco-prop.com/ for about 140 quid.
Have a quick look on here for some picys
http://homepage.ntlworld.com/a.law47/33 ... e%202.html
ed325i
Post Fri Sep 09, 2005 9:11 pm
Hi, Thanks for the info, I am going to mount the engine as far back as I can without moding the firewall and make my own mounts up.
ED
glenn
Engine Transplant Services
Post Fri Sep 09, 2005 9:39 pm
i did my own.
no problem if you can weld.
i inserted something inside to centralise it then welded it up.
try to keep the joint at one of the ends to minimise imbalance.
it's the second i've done
