Check computer oil level warning....
Had to drive into a rough farm yard today and through some long grass. My oil level warning light is on on the check panel, yet the level is fine and the pressure switch goes out normally after cranking. I assume I've damaged the sensor, does anyone know it's location and I'll have a gander tomorrow?, thanks.
- gooner1
- Out humping Reindeer
Mines underneath the engine block, part No 3 in the below,
not sure if it,s in the same place on all types though.
Mines an early 325i, if that helps.
http://www.realoem.com/bmw/showparts.do ... g=11&fg=10
it's on the top of the sump under the alternator
