Can m50 injectors be used as a replacement for m20 2.5 ones
bigdek
Post Sun Sep 04, 2005 5:47 pm
As above .
If yes are they a straight eplacement and are they quieter or do they tick as well ?
E30Adam
Post Sun Sep 04, 2005 7:00 pm
They cause the car to overfuel, use the correct injectors unless you have mods so extreme that the stock item's can't flow enough fuel.
Ant
Retired Team Member
Retired Team Member
Post Sun Sep 04, 2005 9:43 pm
Like mine and fozzys 42 lb/hr jobbies :lol: thats 600cc/min, stock are 149 :eek:
tried the e36 jobbies, cant say they made much diff in terms of noise dude, best bet is a spare set of the correct units and get them cleaned and flowed, @ least you'll be playing with a full deck for sure then
hogweed
Post Tue Sep 06, 2005 12:27 pm
How do you stop the higher-flow injectors overfuelling? Turn the fuel pressure down? In which case, how do you benefit form the extra flow... re-map?
E30 custom active sub for sale - PM for details
