Hello All,
The fuel pump has died on the 1989 316i so I got a replacement from GSF who say that they are all the same from 316i to M3.
However, the fuel pump I got from them is shorter then the one coming out and looks quite different. Both are Bosche though.
Has anyone got any ideas if there is a different pump I need - and more importantly where I could get it.
Thanks in advance
John
316i Fuel Pump
smithy318i
they are all pretty much the same.
some have 2 pipes, while others have 1.
they should be the same length.
some have a circular brown plastic thing on, while others have an oval metal one.
the flow rate is Massive for these pumps (you can drain a half full tank in 10 minutes)
I wouldnt have gone to GSF or ECP for one coz IMO they are Way overpriced.
Scrappy.... "Fiver Mate"
Toby_Unna
- Boost Junkie
there's two different tank sizes and two different pump lengthssmithy318i wrote:they are all pretty much the same.
where can you get a new one cheaper smithy?
fuel fumps DO fail, and will then leave you stranded. i've messed about with plenty Ԛ£5 fuel pumps and they aren't the best idea, they don't like having sat around doing nothing in a scrapyard.
most things i'm happy to replace with second hand but fuel pumps are asking for trouble, i think the GSF price is worth the money
smithy318i
I do agree Toby. I went through 3 scrap yard pumps before i found a good one (i test before i buy)
New ones are expensive as hell though.
however there is a (quite dangerous) fix if your pump breaks...
http://mysite.wanadoo-members.co.uk/smi ... breaks.htm
E30Mark
You hero! how did you manage to get home with out gassing yourself & blowing yourself up?smithy318i wrote:
Personally i think I'll ring the AA, mind you I've never had to call for relay whilst driving a BM. My girlfriends last 2 Renault's are a different story....
PM for details
PM for details
Toby_Unna
- Boost Junkie
iv read about quite a few people doing that
was it on an m10 carb engine or an injection one? i'm impressed if it worked on an injection system! i don't think a washer bottle pump would make 3 bar.
smithy318i
M40 318i
The pump on an M10 is attached to the cam shaft.
JohnH
Thanks, that explains it then - pity GSF in Dublin didn't know that.Toby_Unna wrote:there's two different tank sizes and two different pump lengths
I was going to put in a second hand one too but considering how much of a pain the a**e it is when it goes miles away from home I'm going for anew one. It's be a false economy to have to get the car towed twice.Toby_Unna wrote: most things i'm happy to replace with second hand but fuel pumps are asking for trouble, i think the GSF price is worth the money
Thanks for the help
John
